Good afternoon.
I can’t select a program on the PMM, the machine does not respond to the button.
When you turn it on, it goes to the quick wash and that’s it, the programs don’t switch, the additional buttons do not. functions do not respond,
At the same time, I can change the PMM settings, which I access using the program selection button and the time saving button. That is, the buttons themselves work.
If you press the program selection button immediately after turning it on, it switches once to the next program and that’s it, it doesn’t react to anything else. It’s the same with additional functions (time saving, auto-opening, half load, delayed start) - if you press in the first second after turning on, the function will turn on once, then that’s it, it doesn’t respond...
At the same time, the PMM is normal works according to the program that is selected...
Very similar to a firmware failure, are there options for bringing the brain back to normal?
Gorenje gv561d11 I can’t select a program ⇐ Burning
Bro
Re: Gorenje gv561d11 I can’t select a program
Everything is as usual, unplug for 30 minutes or Reset
- 21 Replies
- 66803 Views
Last post by enzof
