Good afternoon. Has anyone encountered this problem:
Dishwasher bosch silence plus, SMV25FX01R/08, the pump has stopped draining water. When I replaced it with a new one, the problem remained. But the new one works without water. As soon as I fill up the water, it tries to turn on three times and stops, the “faucet” starts flashing. There are no leaks, water fills in, the pump works, everything else works as it should. There is no pressure switch in this car.
Maybe the drain pumps are not suitable for some parameters? Although as on the "native" one, 55V 55Hz.
And it installs into the system without any problems.
The drain pump does not work. ⇐ Bosch
Alexey 2105
Re: Drain pump does not work.
Stepan, good afternoon! Same situation, did you manage to solve the problem?
- 14012 Views
Last post by Castor
