Doesn’t drain work 2 timesDiscount
crazy
Post by crazy »
I have a korting kdi 45165 dishwasher being repaired, it’s not a trivial problem. I start the washer, the first time it works fine, it drains all 3 cycles, as soon as you start it 2 times it stops draining completely, sometimes it doesn’t even drain the first time. The frequency is not clear, but most often it works fine once.
We cleaned everything, the drain hose (the drain pressure is great)
The tube to the preostat, the hole of the preostat itself went through with a wire, everything is clean
Replaced the pump and the switch itself.
The problem remains. I can’t even imagine where and how to dig. Help))
 Re: Doesn't drain work 2 times
Got it, right?
  • Dishwasher doesn't work
    by Anton7 » » in Bosch
    Last post by Anton7
    by Vyacheslav E » » in Hotpoint-Ariston
    Last post by Vyacheslav E
  • The drain pump does not work.
    by Stepan » » in Bosch
    Last post by Graphics
  • The programmer either works or doesn't work
    by Svetlana » » in Other manufacturers
    Last post by Svetlana
  • Doesn't drain
    by Maria » » in Beko
    Last post by Maria
