Ariston LI 460 s\n 50211 1934, voltage on drain pumpHotpoint-Ariston
Castor
Post by Castor »
Can you tell me what voltage should be on the drain pump? It shows 200-201 for me. It is not clear whether the drain pump is faulty or this voltage is not enough. What could be the reason, in the module? How to check the serviceability of the drain pump using resistance. I connect it directly to the outlet, it works. But after 4-5 turns on, it seems to jam and stop. I turn the impeller by hand and it works again. Is 200V ENOUGH for the pump?
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
  • Drain pump part
    by DoubleFace » » in Whirlpool
    Last post by DoubleFace
  • The drain pump does not work.
    by Stepan » » in Bosch
    Last post by Graphics
  • The drain pump does not start
    Last post by Stepan
  • The pump is running, but the clean hose DOES NOT DRAIN!
    by Dmitriy » » in Bosch
    Last post by Dmitriy
