The drain pump does not startBosch
Stepan
Post by Stepan »
Good afternoon. Has anyone encountered this problem:
Dishwasher bosch silence plus, SMV25FX01R/08, the pump has stopped draining water. When I replaced it with a new one, the problem remained. But, the new and old ones work without water. As soon as I fill up the water, it tries to turn on three times and stops, the “faucet” starts flashing. There are no leaks, water fills in, the pump works, everything else works as it should. There is no pressure switch in this car.
  • The drain pump does not work.
    by Stepan » » in Bosch
    Last post by Graphics
  • Drain pump part
    by DoubleFace » » in Whirlpool
    Last post by DoubleFace
  • LSI 48A (Ariston), pump does not start
    by walex » » in Hotpoint-Ariston
  • The pump is running, but the clean hose DOES NOT DRAIN!
    by Dmitriy » » in Bosch
    Last post by Dmitriy
  • Ariston LI 460 s\n 50211 1934, voltage on drain pump
    by Castor » » in Hotpoint-Ariston
    Last post by Castor
