The water pump does not turn offBosch
Alexey 94
Post by Alexey 94 »
Colleagues, tell me where the possible malfunction is. I washed dishes for a long time until a strange sound of a constantly running pump appeared. I opened the door, the machine does not stop the cycle, but the pump runs constantly. The buttons have full color music. I disconnected it from the network, the problem did not go away. I thought there might be contamination in the circuits, I took everything apart and washed it, reassembled it - everything was the same. Even the pump winding probably got heated up, and there was a smell of burnt wiring.
 Re: Water pump won't turn off
Post by Fulcrum »
Most likely, the problem is in the control unit, either water got in, or the board gradually oxidized... But on the other hand, this is Bosh, anything can happen to it...
Air Shower
Post by Air Shower »
Thanks, I’ll do an autopsy.
  • Beko dsfs 1530. The pump does not turn off.
    by Eugene » » in Beko
    Last post by Gennady T
  • The water supply does not turn on/washing does not start.
    by ViperRUS » » in Bosch
    Last post by Vrastrub
  • candy trio 9501x water intake valve does not turn on
    by borodinaries » » in Candy
    Last post by borodinaries
  • When connected to the network, the water inlet valve turns on and does not turn off.
    by DenisM » » in Electrolux
    Last post by Vlad766
  • Bosch. Doesn't pump water
    by GUYSEVKURSE » » in Bosch
    Last post by GUYSEVKURSE
