Beko dsfs 1530. The pump does not turn off. ⇐ Beko
Автор темыEugene
Good afternoon My beko dsfs 1530 took on a full tank of water and started leaking, I plugged it in, the pump turned on and won’t turn off. This happened half a year ago, a week later she came to her senses and started working. Tell me what to do?
kostyanika2007
- My dishwasher: Beko DSFS1530
It’s probably a little late to give advice, but in case it’s useful to someone. You need to open the door slightly and tilt the machine forward to drain the water from the protective pan. there was probably a leak. easy to check. Unplug the machine from everything and place it on either side. remove the protective pan and you will see all the hoses of the machine.
Comfortable
oh dear, can you help me with some advice? I have a slightly different problem - my eyelid has stopped filling with water. I changed the filler valve (or tap, whatever it is called) - it didn’t help. I turn on the machine, turn on the program, the machine is buzzing with something inside, humming, clicking - but no water flows into it.. Why bother further? Maybe some sensor is screwed up?
locomotive 13
Re: Beko dsfs 1530. the pump does not turn off.
kostyanika2007, thank you, you helped a lot. It turned out that a small hose had fallen off.
Free
- My dishwasher: Beko dsfs 1530
Likewise, 2 also flew off at once!! small hoses - to the left and right of the water collector under the filter.
Repair instructions - Remove the plastic under the door, pulling it towards you, unscrew the iron screen (6 screws), remove the "felt boots" sound insulation, find and put on flown hoses, tilt the dishwasher towards you - remove the water from the pan, put everything back, use it. (Tilt it away from you - remove the dirt under the dishwasher :)).
MICHAEL
I HAVE ALREADY TURNED EVERYTHING ON THE SIDE AND EVERYTHING AND THE HOSES ARE IN PLACE AND THE WATER PUMP PUMP WORKS AS WELL AS YOU CLOSE THE DOOR NOTHING HELP APPEARS HER BRAINS ARE FLOATED
kara
Pumping the water from the pan helped, although not immediately. Thank you!
s.denisov
Gentlemen,
On this site I found "Tips about hoses", which I have not yet managed to put into practice, but I will definitely unscrew the pan and do an audit.
And yet...I am asking the eternal "Russian" question and asking for help answering it - WHAT TO DO?
Problem with PMM beko dsfs 1530:
When the power is turned on and the door is closed, the pump starts working to pump out water. So it (the pump) can work for a very long time (I checked, i.e. I waited quite a long time, and also simply poured water into the PMM manually), and it can only be stopped by opening the door and/or turning off the power. In this case, pressing the "pause" button does not lead to any results; the PMM does not see this button, as well as pressing the mode selection buttons.
nTHANK YOU in advance! HUGE AND HUMAN))
my email s.denisov.spb@mail.ru
All hoses are ok. But the water ran over because the filter was not cleaned. Water got into the pan and the leakage sensor was triggered. The pump is constantly running. The program does not start. I washed all the filters, then tilted the car back a little. I drained the remaining water. I wiped everything. Dried. Assembled. Installed. It worked! Advice: Clean the FILTER in a timely manner.
I tilted the machine, drained the water from the pan and everything worked.
Does anyone know how to properly connect the wires to the pressure switch?
drained the water and the machine started working right away. Thank you!kostyanika2007: ↑22 Mar 2015, 18:14 It’s probably a little late to advise, but in case it’s useful to someone. You need to open the door slightly and tilt the machine forward to drain the water from the protective pan. there was probably a leak. easy to check. Unplug the machine from everything and place it on either side. remove the protective pan and you will see all the hoses of the machine.
I disconnected the conductor, I don’t remember where. Do you have a picture of the bottom of the dishwasher? THX
schimchik
Thank you, the advice really helped - I removed the water and the machine started working. Water has accumulated in the pan and is leaking due to “tired” rubber seals.
kostyanika2007, thanks for your advice. Helped me a lot at work, the dishwasher was acting up
ekaterina
kostyanika2007,
Hello, question about dishwasher:
When selecting any program, the program cycle barely starts to start and gives error e 02, while there is definitely water in the system and the pressure is normal. If you open the door and close the error, the program continues to work, but almost after that it starts to show error e 01, which leads to the beeping and the program ending.
Model din 28320.
Sent after 28 minutes 2 seconds:
kostyanika2007, First , it drains before it fills, and then it fills, it fills again, it gives an error, it flows into the pan and the aqua-stop is triggered, which consequently gives an error that there is no water.
Perhaps you are in Minsk? We wanted to invite you to fix it)
Model din 28320.
Gennady T
I tilted the machine on its side - water began to flow, removed the pan, wiped everything dry, assembled it, put the machine in place - turned it on - everything works. The leakage protection sensor consists of an ordinary limit switch and a foam float. Thanks for the useful advice, otherwise I was already planning to buy a new one (the current one has been plowing since 2013)!!!
- 30047 Views
Last post by Gennady 4609
- 28635 Views
Last post by DmitroNik
- 4935 Views
Last post by WaterSpirit
