Beko dsfs 1530Beko
Stanislav
 Beko dsfs 1530
Post by Stanislav »
Gentlemen, I am asking you an age-old "Russian" question and a request for help answering it - WHAT TO DO?
Problem with PMM beko dsfs 1530:
When the power is turned on and the door is closed, the water pump starts working . So it (the pump) can work for a very long time (I checked, i.e. I waited quite a long time, and also simply poured water into the PMM manually), and it can only be stopped by opening the door and/or turning off the power. At the same time, pressing the "pause" button does not lead to any results, the PMM does not see this button, as well as pressing the mode selection buttons.
I found it on this site" Tips about hoses", which I haven’t had time to put into practice yet, but I’ll definitely unscrew the pan and do an audit.
And yet...
THANK YOU in advance! HUGE AND HUMAN))
my email s.denisov.spb@mail.ru
Gennady 4609
My dishwasher: веко 1530
 Re: beko dsfs 1530
Post by Gennady 4609 »
Good afternoon, I am asking you the age-old “Russian” question and asking for help answering it - WHAT TO DO? *
When the power is turned on and the door is closed, the water pump starts working. So it (the pump) can work for a very long time (I checked, i.e. I waited quite a long time, and also simply poured water into the PMM manually), and it can only be stopped by opening the door and/or turning off the power. At the same time, pressing the "pause" button does not lead to any results, the PMM does not see this button, as well as pressing the mode selection buttons.
my email aso4609@mail.ru
  • Beko dsfs 1530 flashes p1 and p3
    by Vsevolod » » in Beko
    Last post by Vsevolod
  • Beko dsfs 1530. The pump does not turn off.
    by Eugene » » in Beko
    Last post by Gennady T
  • Beko DSFS 1530 dishwasher is noisy
    by DmitroNik » » in Beko
    Last post by DmitroNik
  • Beko DSFS 1530 rinse aid end indicator does not light up
    by WaterSpirit » » in Beko
    Last post by WaterSpirit
  • Leak BEKO
    by Kir_lp » » in Beko
    Last post by Cathead
