Good afternoon,
Machine dsfs 1530. p1 and p3 flash simultaneously. When you press the start button, p1 and p3 are constantly lit. Doesn’t respond to button presses.
If you press and hold the start button and press on, after three seconds all the LEDs blink, if you press start again, the machine starts draining, you can hear the pump and circulation pump operating, the sound is normal. After three seconds, the draining stops and the machine again enters error mode (p1 and p3 flashing). Ten heats.
Maybe you have any thoughts?
Beko dsfs 1530 flashes p1 and p3 ⇐ Beko
- 30021 Views
Last post by Gennady 4609
- 28610 Views
Last post by DmitroNik
- 4911 Views
Last post by WaterSpirit
- 15779 Views
Last post by cyrus
