water in bosch SPS58M02RUBosch
Alex
Post by Alex »
good afternoon.
In a new dishwasher, water remains in the tray after washing - the place where the mesh filter is filled with water by about 1 cm.
if you select any program after washing and cancel it, the water is drained, a little remains in well under the filter, where the pump is.
Ie. The pump seems to be working, the filters are clean, why is there water at the bottom of the machine?
My comrades at work also have Boches, but of different models - it’s dry inside, so I’m wondering if my machine is defective.
Thank you.
Is the water directly on top of the mesh or under it? If the former, then something is wrong. Usually the water stays inside, but there shouldn’t be any at the top.
Alex
Post by Alex »
water on top of the mesh.
After starting the drainage program, there is no water anywhere except the recess under the cylindrical filter
  • Bosch SMV40E60EU does not take in water
    by Obormott » » in Bosch
    Last post by Obormott
  • Bosch. Doesn't pump water
    by GUYSEVKURSE » » in Bosch
    Last post by GUYSEVKURSE
  • Bosch doesn't heat water
    by Scorpio » » in Bosch
    Last post by Cuth
  • Bosch srv55t03eu does not pour water
    by Ars » » in Bosch
    Last post by THEN
  • Bosch SPV40E30RU - there is water in the canister
    by Just a passerby » » in Bosch
    Last post by vadim
