Bosch SPV40E30RU - there is water in the canister ⇐ Bosch
Just a passerby
I discovered that there was water in the dishwasher canister (plastic, transparent on the right) after washing and drying was completed. The canister itself is filled to the brim. This is fine?
Dmitriy
Re: Bosch SPV40E30RU - there is water in the canister
I don’t understand where exactly is the water?
Just a passerby
Along the left wall near the dishwasher there is a transparent plastic canister... after hanging the sink it is filled with water...
Dmitriy
Just a passerby, of course, that is, you removed the iron wall...
The water there is This is fine.
Just a passerby
I have a built-in washing machine - and the plastic canister is not protected by anything... I was just surprised that when the machine was done, water remained there - why is this supply needed?
Dmitriy
Just a passerby, I think this canister is a heat exchanger that is used
1) to receive heat from hot water before draining (so as not to spoil the drain pipes)
2) for heat transfer during rinsing (so that dishes do not crack due to sudden temperature changes)
3) for condensation of hot steam during drying
Consequently, this is water that is not used directly for washing dishes, but only for technical purposes. Like a saline solution for an ion exchanger. And water in technical containers is normal.
Dad
Friends, can you tell me where I can download the installation instructions for this unit? Can I have a link?
Thank you!
Thank you!
vadim
How to correctly install the gears in the water distributor in a Bosch dishwasher?
- 16391 Views
Last post by Alex300860
- 2741 Views
Last post by Vegas
