Bosch spv40e30ruBosch
KIN
 Bosch spv40e30ru
Post by KIN »
Hello. The situation is this: the machine was washing dishes, then it beeped as if it had been washed, they opened the tap on the panel, the tap was on, I tried to reset the "start" button for 3 seconds - there was no reaction, I tried again - nothing, but the drain pump was constantly working every minute - one and a half, not a single button responded to pressing, I had to turn off the power. After connecting the power, the panel stopped lighting up, but the pump continued to work even with the door open. Any advice?
 Re: Bosch spv40e30ru
With this error, I had water in the pan, tilted it, drained it and it worked.
  • PPM BOSCH SPV40E30RU/07
    by Serge » » in Bosch
    Last post by Serge
  • Bosch SPV40E30RU/19 does not work
    by Alex300860 » » in Bosch
    Last post by Alex300860
  • Bosch SPV40E30RU - there is water in the canister
    by Just a passerby » » in Bosch
    Last post by vadim
  • SPV40E30RU no cycle start
    by Vegas » » in Bosch
    Last post by Vegas
  • PMM Bosch 45 cm is it possible to install all the internals from Bosch 60 cm, can anyone tell me?
    by Alexey197676 » » in Bosch
    Last post by Oleguk
