Bosch srv55t03eu does not pour waterBosch
Ars
Post by Ars »
Good afternoon!
I start the sink and it starts draining. Then the machine works as if everything is normal until the very end of the washing mode. And as a result, the machine didn’t spill a drop of water on the dishes at all, I don’t know where the water comes from at the bottom, the capsule is also floating at the bottom.
I turn on the reset - it drains all the water from both the bottom and the side of the container. I turn on the sink - water is drawn into the container from the side up to the pressure sensor, then it begins to flow out somewhere (according to the operating mode), but this water does not reach the dishes. Apparently everything goes into conalization.
I removed the valve (I watched videos on YouTube, they seem to be rusting) - it was clean and everything moved smoothly, there was no particular rust.
I removed the pan - I was in a stupor. I thought I’d figure it out, but alas, I don’t know what’s there and how. I decided to write here.
THEN
My dishwasher: SRV55TO3EU
 Re: Bosch srv55t03eu does not pour water
Post by THEN »
Good afternoon. I have the same problem with my dishwasher, tell me how you fixed it and what broke. I removed the valve and it doesn’t move rusty. Thank you.
  • BOSCH SRV55T03EU/38 - wash program time is too low
    by Sergey (Khimki) » » in Bosch
  • Bosch SRV55T03EU/30 - does not complete washing after an hour of operation - cyclic glitch
    by Alex2110 » » in Bosch
    Last post by Alex2110
  • water in bosch SPS58M02RU
    by Alex » » in Bosch
    Last post by Alex
  • Bosch SMV40E60EU does not take in water
    by Obormott » » in Bosch
    Last post by Obormott
  • bosch sms50e02ru - no water supply
    by nickolai.cotov » » in Bosch
    Last post by nickolai.cotov
