Dishwasher leaks AFTER program endsBosch
Sergei K.
Post by Sergei K. »
Hello! PMM - built-in BOSH 2007 It flows "as if from under the left side plastic tank" (the plastic tank itself is intact - I checked it in the bathroom for air bubbles) ONLY AFTER the completion of the program (when the inner walls of the working chamber are abundantly covered with condensate). Is it possible that the metal tank leaks on its own? - I’m at a loss..
If this is so, then what sealant do you recommend?
[Inside on the left, except for the place where the upper basket is attached, the tank is solid; This is on his right side "lateral drainage"] .
  • Bosch SMI63M05EU/02 program ends early.
    by XPS » » in Bosch
    Last post by XPS
  • Siemens sr64e001ru ends the program almost immediately
    by wAnTed » » in Siemens
  • Dishwasher leaks when turned off
    by Catherine » » in Bosch
    Last post by Catherine
  • The dishwasher does not remember the last program
    by mgorshkov » » in Bosch
    Last post by mgorshkov
