Siemens sr64e001ru ends the program almost immediatelySiemens
wAnTed
Post by wAnTed »
Hi all. I bought a used Siemens PMM sr64e001ru, the problem was with a leak, otherwise the machine worked flawlessly (according to the seller). I removed the pan, there was a slight leak from the glass (Bosch and Siemens disease... sealed it). I replaced the door bottom seal (it was torn).
I turned on the machine, no errors. I started it at 70 degrees for testing. The machine begins to “buzz”, drains the water or whatever, then there is silence for 2-3 seconds, then a sound is heard, as if it is trying to turn something (a motor or whatever) and a squeak is heard, the end of the program. I open the door, it’s dry inside, the “end” light is on. I don’t understand what’s wrong.
No water flows into the heat exchanger (plastic container on the side).
I rang the aquastop coil - there is no signal, as if there was a break, but when supplied directly from a 220V outlet, the coil is triggered and clicks inside. The rubber band that blocks the channel does not visually come off, but I blew it with air, and you can hear the air coming out somewhere inside the machine and you can lift it up 3-4mm with a small screwdriver. I think that water is supposed to be pushed through by pressure.
What else to see? Where to dig?
Kreutzkopf
 Re: Siemens sr64e001ru ends the program almost immediately
Post by Kreutzkopf »
See circulation pump. Ring the pump winding and heating element
Artem
Post by Artem »
  • Dishwasher leaks AFTER program ends
    by Sergei K. » » in Bosch
    Last post by Sergei K.
  • Bosch SMI63M05EU/02 program ends early.
    by XPS » » in Bosch
    Last post by XPS
  • 11477 fills and immediately drains water
    by Elias » » in Hotpoint-Ariston
    Last post by Kreutzkopf
  • Siemens SE66T373EU/01
    by Vadim » » in Siemens
    Last post by Vadim
  • SR24E205RU siemens
    by Andrew » » in Siemens
    Last post by Pompag
