Midea mfd 45 s 100 light and musicMidea
Victor 86
Post by Victor 86 »
The four right indicators began to flash alternately. There are no visible defects inside. The mesh in the hose was cleaned. The drain pump is working. There is no water in the pan. After disassembling and reassembling everything, it started up once. I washed it for 20 minutes, drained the water and again the four indicators flashed alternately. Has anyone encountered this? Where to dig?
Electronic Programmer
 Re: Midea mfd 45 s 100 light and music
Post by Electronic Programmer »
Victor 86, DD tell me, did you find a problem in the dishwasher? I got the same problem
Barometer
Post by Barometer »
Same problem. It seems like the leakage sensor works like this
Bagerny
Post by Bagerny »
Upssi irooims
Bagerny
Post by Bagerny »
Replaced the capacitor with a 16v 100 uF on the control board. Dishwasher midea definitely 12-5203
  • Midea
    by Error e1 » » in Midea
    Last post by Error e1
  • E4 dishwasher Midea
    by Marina » » in Midea
    Last post by Retraction
  • MIDEA - the top sprinkler has fallen off
    by Rude » » in Midea
    Last post by Compressor Oil
  • Midea 45 cm MFD45S110WI. Flashing indicator
    by Lyudmila » » in Midea
    Last post by Lyudmila
  • Midea MCFD 0606 water leak
    by Small flat » » in Midea
    Last post by Matrix
