E4 dishwasher MideaMidea
Marina
 E4 dishwasher Midea
Post by Marina »
Hello, dishwasher Midea (standing in the kitchen), I started the dishwasher, everything was fine, but after 10 minutes it issued f4 first, then I decided to turn on off, and already issued the e4 command, before that there was a situation in the bathroom, the water was not flushing well, there was a blockage, I I tried to clean it, the pipe is common for drainage, it turned out that there was a strong blockage, I removed it, everything drains normally, but the machine still gives an error, I tried to turn it off as advised for 20 seconds, it didn’t help, I removed all the water from the tray, which the machine did not I was able to lower it because showed an error, what should I do in this situation? Built-in machine
Retraction
 Re: E4 dishwasher Midea
Post by Retraction »
Marina, check that the drain is connected correctly, it should be at least 40cm from the floor
  • Midea
    by Error e1 » » in Midea
    Last post by Error e1
  • MIDEA - the top sprinkler has fallen off
    by Rude » » in Midea
    Last post by Compressor Oil
  • Midea mfd 45 s 100 light and music
    by Victor 86 » » in Midea
    Last post by Bagerny
  • Midea 45 cm MFD45S110WI. Flashing indicator
    by Lyudmila » » in Midea
    Last post by Lyudmila
  • Midea MCFD 0606 water leak
    by Small flat » » in Midea
    Last post by Matrix
