Midea MCFD 0606 water leakMidea
Small flat
Post by Small flat »
Good day! In general, the washing machine is MCFD 0606. The water leakage error comes on consistently once a month, accompanied by water leakage from under the machine. Contacting the service center did not solve the problem. Subsequently, I called the craftsmen to the house. The problem was not solved. Water flows steadily, once a month. When removing the pan, I do not observe any obvious leaks at the junction of the hoses, engine and pump. After drying with a rag it works for about a month and then everything starts again. Can anyone give me some thoughts? Thank you in advance.
Matrix
 Re: Midea MCFD 0606 water leak
Post by Matrix »
Maybe increased foaming?
  • Midea
    by Error e1 » » in Midea
    Last post by Error e1
  • E4 dishwasher Midea
    by Marina » » in Midea
    Last post by Retraction
  • MIDEA - the top sprinkler has fallen off
    by Rude » » in Midea
    Last post by Compressor Oil
  • Midea mfd 45 s 100 light and music
    by Victor 86 » » in Midea
    Last post by Bagerny
  • Midea 45 cm MFD45S110WI. Flashing indicator
    by Lyudmila » » in Midea
    Last post by Lyudmila
