Repair Hotpoint ariston LST 41677Hotpoint-Ariston
Igor N
Post by Igor N »
Good afternoon! Help me repair the Ariston LST41677 dishwasher. The circulation pump stopped working, bought a new one and installed it. I turned it on, it seemed to work, but the pump worked somehow in waves. After several starts, errors appeared (there is no display on it) but the on buttons blinked. first mode and third. Turned it off, then turned it on after a while. again, it doesn’t seem to show any errors, but the pump also works in waves, and the PMM takes in water, runs for 2-5 minutes and drains the water. And it can work like this in a circle until you turn it off.
Carp
 Re: Repair Hotpoint ariston LST 41677
Post by Carp »
Maybe someone has encountered such a problem. The inlet hose is clean (checked), the pressure switch is also in order, it blew into the pressure switch tube, and it also blows easily. I can’t understand what the problem is, it worked until recently without any problems. Help people
  • Personal experience of self-repair of Hotpoint-Ariston LL40
    by Vitaly » » in Hotpoint-Ariston
    Last post by Vitaly
  • Hotpoint ariston adls 7
    Last post by Louisa
    Last post by Port
  • Hotpoint Ariston lst 11477
    by Alexey78 » » in Hotpoint-Ariston
    Last post by Alena
  • Hotpoint ariston LST 11677
    by user3452 » » in Hotpoint-Ariston
