Can there be self-draining?Beko
Romec4707
Post by Romec4707 »
Hello. Dishwasher Beko DIN24310 The question is, can the water itself drain during washing through a drain hose, such as a self-draining hose, if it is not properly connected to the sewer? The hose lies on the floor and goes directly into the sewer pipe. The pipe is raised from the floor by 10 centimeters. During washing, the following happens. The machine fills with water and starts washing. If you open the door, the water is at the bottom, the pressure is good, the blades rotate, splashes fly. After 20 minutes there is no water at the bottom, the pressure is weak, even the blades do not spin, the steam remains, the powder is not washed out. An hour later, when the rinsing mode probably turns on, the water is filled again, the washing begins, and after 10 minutes there is silence again, the water barely splashes. Well, the dishes remain dirty. We don’t know what to think anymore, the machine is half a year old and it was like this from the beginning, it was connected by a Kitchen installer. So I’m thinking, maybe the drain is below the pump and the water flows out on its own, and accordingly where does the pressure come from if there is not enough water. Is it possible for the water to flow out on its own, or does it just end there with a pump? And why then isn’t a new one recruited? Or did she gain as much as she needed and that’s it? But this doesn’t always happen, sometimes it washes well, and the pressure is good throughout the cycle. One good, two bad.
Slope
 Re: Can there be self-draining?
Post by Slope »
You may have overdosed on detergent, there is a lot of foam, just in case, check the filters and impellers for clogging
Romec4707
Post by Romec4707 »
There is no foam, the impellers are perfect, I checked them. Proroshek doesn’t get enough sleep when there’s such pressure, where will the foam come from? The filter is clean. She washed like this even after washing the dishwasher itself with detergent. But the main thing is that when you wash yourself empty, the pressure is good.
Slope
Post by Slope »
How is it that the powder does not fall out? The cuvette then opens, self-draining is unlikely, there is a valve there and it would show an error
Glass ceramics
Post by Glass ceramics »
The powder is washed out from there under the stream; if there is no pressure, then there is no stream. Accordingly, if the powder gets a little wet, it sticks and cannot fall out on its own. Today I picked up the hose and everything cleaned up great.
Cupcake
Post by Cupcake »
Did you lift the drain hose and water appeared?
Ignatius
Post by Ignatius »
Cupcake, he had a bad dream along the way :shock:
Cupcake
Post by Cupcake »
Ignat, there really is a valve there, it doesn’t open while PMM is washing the dishes, but then the drain hose rose and water appeared when the drain valve was closed :fool: I would also understand if the inlet hose needed to be raised, It happens because of this that there is just poor water pressure :Search:
Glass ceramics
You seem to be a complete 0 in this matter. And these are the craftsmen who do the repairs. take a look. The meaning is the same.
The dishwasher draws a certain amount of water, and then this water circulates. There is no topping in it. If the water goes into the sewer system, the machine will not see it. Where do you think the water from it goes then? I wrote that it washes for about 15 minutes, the water stands at the bottom, and then it goes somewhere, and the drain pump does not work. And then she drives the leftovers, so there is no pressure.
Glass ceramics
And what does the inlet hose have to do with it? What is the pressure in the water supply there? Is he coming out of a bucket of water?
Artem
Post by Artem »
Glass ceramics, did you find out where the water goes? Several times I also had water leak out somewhere, as we later found out it was in the pan (((
Ion
Post by Ion »
Yes, now I’m sure that this was the problem. More than 2 weeks have passed since the drain hose was lifted, and now the dishwasher cleans perfectly. The pressure is excellent.
Romec4707
Post by Romec4707 »
3 months have passed, the flight is excellent. The water does not drain, the dishes are washed.
  • Stopped draining and starting
    by Dimon » » in Candy
    Last post by Dimon
  • Draining water after a minute of operation
    Last post by Anton
  • PMM Vestel 6041W displays error F5 after draining
    by Sergey 62 » » in Vestel
    Last post by Kvasius
  • The pump blades are spinning, but the water is not draining
    by the decorations » » in Bosch
    Last post by the decorations
  • The Bosch dishwasher leaves at 0:00 17 minutes before the end without draining the water.
    by Vadim » » in Bosch
    Last post by Vadim
