The Bosch dishwasher leaves at 0:00 17 minutes before the end without draining the water. ⇐ Bosch
Vadim
The BOSCH dishwasher adds 8-10 minutes 12-14 minutes before the end of the short cycle, then either works normally until the end, but more often 17 minutes before the end it goes away at 0:00, like it’s finished, you open the door, and it’s full of water. The water is hot. If you restart it, the water will drain normally before the cycle starts, but everything will repeat.
PMM Bosch SGV57T23EU/01 30 minutes before the end of the program, water is not added.
by Alex. Aleks. » » in Bosch - 3 Replies
- 5696 Views
Last post by UGR
