PMM Bosch SGV57T23EU/01 30 minutes before the end of the program, water is not added.Bosch
Alex. Aleks.
Post by Alex. Aleks. »
The dishwasher
Bosch SGV57T23EU/01
The PMM turns on, draws water, and washes. At first the water is cold, then it warms up. After time, the water is drained and new water is added. The machine then rinses with cold water. Afterwards, the water is drained again, the drain pump stops (until the end of the entire wash, about 30 minutes remain) and new water is not poured in, while the circulation pump works, and so on until the end of the wash time. After the time has elapsed, the machine stops and signals the end of the wash. PMM does not give any errors. When you start another program, the same thing happens, when there are about 30 minutes left until the end of the wash, only the circulation pump works and after the wash time has elapsed, the machine turns off. If you turn on the rinse mode, it runs without problems until the end. Please tell me what could be the cause of the malfunction?
Pompag
 Re: PMM Bosch SGV57T23EU/01 30 minutes before the end of the program, water is not added.
Post by Pompag »
First of all, you need to look at the solenoid fill valve; it is located on the left side of the machine when looking at it. Usually it jams after 12-14 years of operation of the machine. I made a video on this topic.
Pompag
My dishwasher: SRV55Т03
Post by Pompag »
Video link;
UGR
Post by UGR »
Try reading the instruction manual, it will help in your case
  • The Bosch dishwasher leaves at 0:00 17 minutes before the end without draining the water.
    by Vadim » » in Bosch
    Last post by Vadim
  • Connection diagram for PMM control module Bosch sgv57t23eu 10
    by Ivan Susanin » » in Bosch
    Last post by Ivan Susanin
  • Bosch SGV57T23EU - When pressing ON, only the floor lamp blinks
    by Palmer » » in Bosch
    Last post by Palmer
  • First start. Doesn't heat the water and turns off after 20 minutes :(
    by Lisa » » in Bosch
    Last post by Chipmunks
  • Error E24 does not drain water, stops after 40 minutes of operation
    by Olesya » » in Bosch
    Last post by Olesya
