Muddy waterOther manufacturers
We investigate
 Muddy water
Post by We investigate »
GOOD DAY. I HAVE THE SUCH PROBLEM, I DOUBT whether MY DISHWASHER RINSES THE DISHES GOOD. AND THIS IS WHAT I NOTICED, IF YOU PLACE AN UPVERTED GLASS AT THE END OF THE CYCLE WHEN YOU RINSE THERE IS CLOOKY WATER IN IT AFTER THE FINISH OF WASHING. AFTER THIS I RUN 2 ANOTHER QUICK CYCLES WITHOUT DETERGENT BUT THE WATER IS STILL CLOUDY. WHAT DOES THIS MEAN?
THE DISHWASHER IS CLEAN,, THE FILTER IS CLEAN IN PERFECT CONDITION. WHY IS THAT?
Funtic
 Re: Cloudy water
Post by Funtic »
Turbid
 Re: Cloudy water
Post by Turbid »
:ROFL:
  • Muddy water at the bottom of the PMM
    by AndreiZ » » in General questions about dishwashers
    Last post by Support
    by Olga Olga » » in Indesit
    Last post by Olga Olga
  • Overflows water. Leaking from water hardness regulator
    by Artem » » in Electrolux
  • Water does not flow into the dishwasher. No water. Reasons for the error.
