Error E1Midea
Muzzy
 Error E1
Post by Muzzy »
Good afternoon.
Weissgauff BDW6062 D machine. If I understand correctly, the same Midea. Correct me if I’m wrong.
New. She stood there for a long time. Plugged it in, water poured in. After a couple of minutes, it drains the water with error E1. There is water pressure. The hose was suspended by 40 cm.
It turns out that the circulation pump does not start. Could it jam during downtime?
 Re: Error E1
The Weissgauff trademark belongs to the Russian Group of Companies “Megalex”. The production facilities are located in Turkey, China, Romania and Russia. Has nothing to do with Midea. Error E1 “water supply tap is closed, there is no water in the pipeline or the water pressure is too low”
Abyssinian Well
 Re: Error E1
Post by Abyssinian Well »
There is definitely pressure in the pipe, because... The water comes out of the tap well. Then maybe aquastop does the brains?
Retraction
 Re: Error E1
Post by Retraction »
Just in case, look at the filter on the inlet hose, maybe something is clogged, try hanging the hose differently
Abyssinian Well
 Re: Error E1
Do you mean hanging the inlet hose?
I have now checked the aquastop inside - there is resistance. I try to disconnect the wires from the external one, but it doesn’t work, they fit well. Should the external one be measured with it turned off?
Retraction
 Re: Error E1
Well, yes, sometimes the inlet hose is a little wrong and the machine is capricious, most likely everything is fine with your aquastop, I meant to check the filter on the inlet hose, there was already such a problem on the forums with your model PMM, as they wrote, they disassembled the filter in the inlet hose, cleaned it and the problem went away
Abyssinian Well
 Re: Error E1
The mesh is clean. The hitchhiker itself seems to be non-removable.
Now the reed switch began to suspect. If I understand correctly, then it should measure the required amount of water for the washing cycle, and after turning off, give a signal to the brain to turn on the circulation pump. This doesn’t seem to be happening. How can I check it? I saw that they were bringing a magnet and ringing it. For me it was in a closed state all the time. Or did I measure it wrong?
Retraction
 Re: Error E1
Do you have a new PMM, warranty?
Abyssinian Well
 Re: Error E1
Yes, under warranty. I’m just afraid that it will take more time and money to deliver, pick up and, possibly, repairs.
Retraction
 Re: Error E1
A product weighing more than 5 kg, paragraph 7, article 18, of the law on the protection of consumer rights, so there is no need to go anywhere, if there is a guarantee, then why carry out experiments? They may later deny the warranty if there is a serious defect.
Anastasia
 Re: Error E1
Post by Anastasia »
Hello, tell me what to do, I started the dishwasher and turned off the water, it showed an E1 error?
Retraction
 Re: Error E1
After the water is turned on, the PMM should continue the washing cycle, the error will turn off
Yoke
 Re: Error E1
Post by Yoke »
:swim: Anastasia, have you turned on the water?
Glass ceramics
 Re: Error E1
Post by Glass ceramics »
It turns out that error E1 may be directly related to the Midea PMM. Weak pump. If its performance drops or becomes clogged, error E1 is displayed. Diagnostics based on the flow of water into the internal cavity of the PMM,
Me again
 Re: Error E1
Post by Me again »
What if error e1 occurs during washing? The model has a mini water tank and does not depend on water supply. The pump that supplies water to the bunker is working, and the error does not occur during filling, but during washing. Maybe immediately, maybe during drying. What is this?
Ion
 Re: Error E1
Post by Ion »
Most likely the pump is LP002D2. Look at the water supply during operation.
Ion
 Re: Error E1
Post by Ion »
Shock absorber
 Re: Error E1
Post by Shock absorber »
Pmm mfd45s320w. After 3 minutes of operation, error e1. Water remains in the machine. When restarted, the water is drained and the process starts all over again. Aquastop has been replaced.
Anal cough
 Re: Error E1
Post by Anal cough »
Admin, don’t delete messages, otherwise you’ll catch a cold!
Wooden Admin
 Re: Error E1
Post by Wooden Admin »
Sorry, I won’t do it again!
Wood
 Re: Error E1
Post by Wood »
Anal cough, caught a cold?
Anal cough
 Re: Error E1
Wood, mildly cold...
Cam
 Re: Error E1
Post by Cam »
Hello, can you tell me how to disassemble this PMM?
too harmful
 Re: Error E1
Post by too harmful »
Unscrew the filler neck with the filter section from the top (just rotate the ribs inside counterclockwise), smoke the self-tapping screws in the ceiling of the washing chamber on the right and left, then slide the top panel back and remove it, pull the back panel up and it will fall off. There will be screws for fastening the side panels on the top and back. The bottom is attached to 4 self-tapping screws from below, a drain hose clamp and a fill valve. You can only take out the black pan with the float sensor, unscrew the self-tapping screw in front, pressing the tab, which you need to pull down and pull the pan towards you. Sensor on latches. The clamps on the hoses are disposable, you need to immediately prepare a replacement for the usual ones with screws. The warranty will be void.
Isn’t it possible to find a good small 220V pump instead of the original one? Not suitable for coffee machines, productivity is too low.
too harmful
 Re: Error E1
A little more about the pump: it started working normally after a few pokes with a screwdriver into the half filled with epoxy (in the hope that it would just wedge, maybe it would wedge). How long and when will it jam back - I don’t know. Perhaps it lacks some kind of lubricant, or maybe the design is crooked. Removing and disassembling while too lazy just works.
Elena R.
 Re: Error E1
Post by Elena R. »
Can you tell me what it looks like and where the half filled with epoxy is located?
burn
 Re: Error E1
Post by burn »
*x)
Compander
 Re: Error E1
Post by Compander »
Hello. The machine draws and drains water in 2 steps. But it doesn’t finish the job. It gives error e1. Water pressure is good.
Puppeteer
 Re: Error E1
Post by Puppeteer »
Dishwasher midea leaks on the sides of the door...??? What could it be
Compensatory
 Re: Error E1
Post by Compensatory »
Puppeteer: 01 May 2023, 10:00 Dishwasher midea leaking on the sides of the door...??? What could be
Overflow of water and check the PMM installation level.
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
