Bosch SPV25FX10R/46 Error faucet blinkingBosch
Excavation
Post by Excavation »
Please help! Bosch SPV25FX10R/46 NO LEAKS! the problems started in the middle of the cycle, the faucet stopped blinking and the pump did not drain, turned it off at night, then it worked 5 or 7 times and the faucet blinked again. Two weeks later it worked differently: no leaks! In the middle of the cycle, before rinsing, the water drains and the faucet blinks with error, I open the steam there, it comes out somewhere around 60 degrees, I try to start it, turn on any mode, close the door, two clicks occur, the pump and pump twitch and the faucet blinks again. Then, over the course of a month, every other day, it was started up a couple of times, doing full washes and again dancing with tambourines, again the error flashes, the water faucet is nowhere to be found, we start it, it clicks twice and the faucet again. Two days ago it somehow started up with a second-long hum and in the middle of the sink the pump again drained water and the ERROR TAP FLASHES. Now I think it’s completely screwed up, it won’t start at all. I TURN ON THE MODE, CLOSING THE DOOR. THERE TWO CLICKS OF THE RELAY AT ONCE AND SOMETHING IS JERKING AND INSTANTLY WRITES ERROR THE TAP IS OPENING, THERE IS NO LEAKAGE! I ASK FOR HELP, THE TWO MASTERS WERE SEEING ZERO SENSE.
© Source: Re: Bosh SMV25FX01R does not complete the cycle, the faucet blinks (Post by Anonymous #2518)
 Re: Bosch SPV25FX10R/46 Error faucet blinking
I disassembled everything down to the screw, everything was clean and dry, the machine was new for the second year and was not used often.
pasha
Post by pasha »
Hello
Very similar problem
Did you solve it?
  • Error e15 (faucet indicator flashes), but I don’t see any leakage
    by Pin » » in Siemens
    Last post by Pin
  • Bosch SMV25FX01R does not complete cycle, faucet blinks
    by Not a bit » » in Bosch
  • The tap on the SD4P1B dishwasher is blinking
    by VladimirAl » » in Bosch
    Last post by Fury
  • Indesit dsg 0517. What does the blinking indicator mean?
    by Sergey1632 » » in Indesit
    by Sibiryak22 » » in Candy
    Last post by Sibiryak22
