Error e15 (faucet indicator flashes), but I don’t see any leakageSiemens
Pin
Post by Pin »
Hello!
After 5-10 minutes of operation, the dishwasher beeps and stops working. The faucet indicator (e15) flashes on the panel.
I cleaned the water supply, drain, checked the blockage, checked the sump pump impeller, checked the pan (dry, where I could reach).
What could be the matter?
PS. I called a technician, he took it apart and found a small play in the circulation pump (inverter). After that, I assembled it, turned on the machine, and this time it suddenly worked for about an hour, but still did not wash and again gave error e15.
  • The PMM turns on and the tap indicator flashes
    by cyrus » » in Bosch
    Last post by cyrus
  • Bosch spv 40e20ru "check water supply" indicator flashes
    by Friend7777 » » in Bosch
    Last post by maxidgan
  • The faucet indicator is on
    by Svetlyak » » in Bosch
    Last post by Svetlyak
