Pamagiti! The Bosch car is about 9 years old. Not young of course. There were no problems before this. I turn it on, set the mode, it starts pumping water, then a click apparently opens the supply. Then the water seems to start filling in, but not for long. The red tap lights up and the machine beeps periodically, and begins to seem to circulate water inside, while draining just a little water, also periodically. Then it freezes, there is no visible water at the bottom, like when washing. There is no display, so we can’t understand what she needs. The filters inside the chamber and on the inlet hose were cleaned, apparently the problem is inside the machine itself. I can send you a video. Tell me where to dig!
The faucet indicator is on ⇐ Bosch
Svetlyak
https://drive.google.com/file/d/1PHsu3x ... p=drivesdk
- 1367 Views
Last post by Pin
- 10090 Views
Last post by Sergey.Korenskoy
