The faucet is on fire on the new Bosh PMBosch
Sergey.Korenskoy
Post by Sergey.Korenskoy »
Hello. Bosh SPS25FW13R/01 was purchased to replace the old Siemens PM. During the warranty period, this machine’s "faucet" icon began to light up periodically. It caught fire around the time of drying. Under warranty, they replaced the water inlet sensor (on the right) and the circulation pump (!!!). The problem did not disappear, on the contrary, it began to appear almost every time I wash it. Often there is water left in the “glass” for the filter. It happens that the tap lights up and there is dirty water, the washing is interrupted. If you turn it off and turn it on again, the water is discharged without any problems, i.e. there is no blockage... Also, the faucet can light up at the very beginning of the washing cycle. In general, the problem is "floating", diagnostics in the service center naturally did not reveal anything.
The voltage in the network is 2019-220V. I tried installing a water pressure reducer at 3 bar at the inlet, the filter is always clean, the result is the same.
Please tell me what the problem with this machine could be. I read reviews on the website of one large retail chain, for this MP there are reviews with exactly the same problems...
  • PMM bosh
    by Ilya » » in Bosch
    Last post by Ilya
  • The faucet indicator is on
    by Svetlyak » » in Bosch
    Last post by Svetlyak
  • At 70 degrees the faucet lights up
    by Sergey Egorov » » in Bosch
    Last post by Fuchs
