Bosch spv 40e20ru "check water supply" indicator flashesBosch
Friend7777
Post by Friend7777 »
The indicator blinks, does not respond to buttons. This has happened before, they called the technician, and when I pressed something, the machine started working. Now the same problem is happening again.
naokne
 Re: Bosch spv 40e20ru "check water supply" indicator flashes
Post by naokne »
good afternoon, we have the same problem, two cycles of adding water and washing go through and then the rapidly flashing water supply icon lights up, tell me how to fix it, thanks in advance!!!
Same symptoms, haven’t found a solution?
AVK13
Post by AVK13 »
The problem was a strong water pressure, I closed the tap at the entrance to the dishwasher a little and it began to work normally.
maxidgan
Post by maxidgan »
Gentlemen, tell me what the problem was, I want to save the family budget!
  • The PMM turns on and the tap indicator flashes
    by cyrus » » in Bosch
    Last post by cyrus
  • Error e15 (faucet indicator flashes), but I don’t see any leakage
    by Pin » » in Siemens
    Last post by Pin
  • bosch sms50e02ru - no water supply
    by nickolai.cotov » » in Bosch
    Last post by nickolai.cotov
  • No water supply to the yoke
    by Denis » » in General questions about dishwashers
    Last post by Denis
