Error 02 in the dishwasher eyelidBeko
Katandras
My dishwasher: Din 28320
Post by Katandras »
In the eyelid machine, when you select any program, it works until the moment when the rinsing cycle should begin, and then it displays error e02. When choosing just the rinse mode, sometimes it works for a couple of seconds, and the same error. Everything is definitely ok with the inlet hose, and with the water pressure in the system, the pump is new.
What could it be?
Could it be a fluometer?
We just screwed on a new aquastop with tubes . If she doesn’t have enough water, why is everything ok until the moment in the program reaches the rinsing mode? After all, it draws water quite vigorously and quickly.
Two repairmen came and decided nothing except to replace the inlet hose and pump. But the problem did not go away.
Artem
 Re: Error 02 in the dishwasher eyelid
Post by Artem »
There is no water in the water supply, the water supply tap is closed or poorly opened, low water pressure, incorrect water connection, the inlet filter is clogged, the water supply hose is clogged, pinched or damaged, the door is not closed, there is a problem with the door locking, the inlet valve is faulty, the The water level sensor is working, the control board is faulty, the aqua-stop has failed, there is a system glitch / de-energize the device completely for 15-30 minutes /
  • Samsung dishwasher error E3
    by Andrey Shagrov » » in Samsung
    Last post by Andrey Shagrov
  • Bosch dishwasher error E09
    by Sweeps » » in Bosch
    Last post by Sweeps
  • Dishwasher neff error E15
    by Marina » » in Other manufacturers
  • Dishwasher KRONA error E3
    by Master » » in Chrono
    Last post by Elena+
  • Error e01 and e02 in the Veko dishwasher
    by AndreKot » » in Beko
    Last post by Vulcanizer
