Error e01 and e02 in the Veko dishwasherBeko
AndreKot
Post by AndreKot »
Hello, a question about the dishwasher. Model Beko din 28320.
When you select any program, the program cycle just starts to start, it gives error e 02, and there is definitely water in the system and the pressure is normal. If you open the door and close the error, the program continues to work, but almost after that it starts to show error e 01, which leads to the beeping and the program ending.
First, it drains until it fills, and then it fills, it fills again, it gives an error, it flows into the pan and the aquastop is triggered, which consequently gives an error that there is no water.
n
How to fix it so it works?
Vulcanizer
 Re: Error e01 and e02 in the Veko dishwasher
Post by Vulcanizer »
Did you manage to figure out what the problem was?
  • Error e01 and e02 in the Veko dishwasher
    by AndreKot » » in Beko
    Last post by AndreKot
  • Bosch dishwasher error E09
    by Sweeps » » in Bosch
    Last post by Sweeps
  • Dishwasher neff error E15
    by Marina » » in Other manufacturers
  • Dishwasher KRONA error E3
    by Master » » in Chrono
    Last post by Elena+
  • Samsung dishwasher error E3
    by Andrey Shagrov » » in Samsung
    Last post by Andrey Shagrov
