Dishwasher KRONA error E3Chrono
Master
Post by Master »
The loaded dishwasher with a short wash cycle (without drying) does not heat the water and constantly displays error E3, but if you just restart it for the same cycle without dishes, it heats the water perfectly and washes according to the program. The filters are clean. Well, it doesn’t want to work in the loaded version. The reason of that?
 Re: KRONA dishwasher error E3
Information on how to resolve the E3 error, from the 123bt website, online service section
n
REPAIR.
1- Shut off the main water.
2- Open the machine, pull out and wash both filters (especially and always the cylindrical fine mesh filter) with a stiff brush .(so that all cells are clean)
3- WITHOUT INSTALLING THE FILTERS IN PLACE, RINSE THE MACHINE WITH HOT WATER.
HOW TO DO THIS:
A) Boil water in a saucepan or kettle 2-3 liters.
B) Open the machine door, if it was closed, and pour boiling water onto the bottom (there should be no dishes in the machine).
B) Press the “NETWORK” button and turn on the last program.
D) Close the door
The machine will carry out the draining program, and since the main water is turned off and will not enter the machine, after draining , press the “POWER” button, that is, turn off the machine, open the door and !
CARRY out the WASHING OPERATION IN POINTS A, B, C, D AT LEAST 3-4 TIMES.
After completing all operations in After washing, install the cleaned filters in place, open the main water and carry out a test wash.
THE PROBLEM WILL BE SOLVED
Elena+
Post by Elena+ »
Is the hose for Indesit and Ariston suitable for PMM Krona?
  • Krona bdx 45096 ht error
    by Rulyasik » » in Chrono
    Last post by Rulyasik
  • Bosch dishwasher error E09
    by Sweeps » » in Bosch
    Last post by Sweeps
  • Samsung dishwasher error E3
    by Andrey Shagrov » » in Samsung
    Last post by Andrey Shagrov
  • Dishwasher LTF11S111 error 15
    by pavel » » in Hotpoint-Ariston
  • Error e01 and e02 in the Veko dishwasher
    by AndreKot » » in Beko
    Last post by Vulcanizer
