Is a top sprinkler or rocker needed?General questions about dishwashers
Misha
Post by Misha »
Hello. Choosing a 60cm dishwasher for a new apartment. So far I have chosen this electrolux ema917100l, but in the store the seller noticed that there was no upper sprinkler. Having looked at others, including those with a top tray for forks and spoons, I saw that some of them also do not have a top feed. That is, the water reaches the cutlery from the rocker between the lower and loaded upper drawers? Now I have a narrow electrolux with a top one, so I somehow didn’t even attach any importance to this. What should I do?
  • The sprinkler flies off
    by Alexei » » in Hansa
  • MIDEA - the top sprinkler has fallen off
    by Rude » » in Midea
    Last post by Compressor Oil
  • PMM LG LD2060WH lower rocker arm does not rotate
    by Wisdom » » in LG
  • Bosch SMV47L00RU/09 the upper rocker arm does not work.
    by Alexeyka » » in Bosch
  • Help needed, Bosch dishwasher
    by Timur » » in Bosch
    Last post by Timur
