Neff s51t65x4ru (sn66t55ru) does not heat waterBosch
pka008
Post by pka008 »
Like all Boshes, mine has a leak, but I couldn’t completely solve it; the homemade silicone gasket leaks during breaks for more than a week. This time I decided to take it apart and wipe it with a rag, but apparently the urine got to my head and I climbed from the right side, although it was possible from the facade, in short, I pulled the board off, after assembly it stopped heating, no errors. The heating element on the Chinese cartoon is 19 ohm
, the temperature sensor is also normal, 12 ohm at the ends. The coils on the board have windings of 390 somewhere. Also there, during the last "repair", the master installed an Olmt-1 decoy resistor instead of a zeolite heating element, it seems to show the same thing with his 278k. While I was still poking around and the door sensor grunted, I now need to look for this Boshev miracle at a showdown. I’m thinking of giving up, finding and changing the hall sensor and taking the car to the village for hot water and putting a new beko or midea in the apartment.
Does anyone have any thoughts on the cause of cold car washes?
  • ESL45010 does not heat water
    by JustAMan » » in Electrolux
    Last post by JustAMan
    by Yulia » » in Electrolux
  • Smv50m50ru /74 does not heat water
    by Chinese » » in Bosch
    Last post by Chinese
  • HSIE 2B0 does not heat water
    by PotatoMonster » » in Hotpoint-Ariston
    Last post by I kneel down
  • doesn't heat water
    by Vitana » » in Siemens
