Cdcf 6-07 turns off after filling the washing chamber with waterCandy
Dishwashers Candy
Denis3331
Post by Denis3331 »
Greetings to forum members. This problem arose 2 years ago. I called a technician, he took the car apart and turned it on. She earned it. Turned it off. And I ran it like that a couple of times. And it worked properly during diagnostics. What was the cause of the malfunction, the master himself did not understand. He paid the master 2 thousand rubles for this. Now there is a similar situation in the breakdown - when you turn it on, the water drains, then water enters the washing chamber, it triggers the opening of the compartment with detergent and the washing stops. After which I manually pumped the water out of the machine and left it to dry, but to no avail. I took the car apart, didn’t find any leaks inside, wiped it with a cloth, sang its praises... But this brute doesn’t want to be friends. There are actually several questions: what could be the matter? How much will it cost to fix the breakdown (cost of spare parts)? Or don’t give a fuck and buy a new (this machine is 5 years old) dishwasher? I don’t turn to the specialists, about 2 thousand for disassembling and pressing a couple of buttons, a residue remains, while not identifying the cause of the breakdown 2 years ago. I don’t want to get the title of sucker of the year.
I can’t attach a video of the dishwasher working here.
Thank you.
  • The PM stops the washing cycle, there is a little foam inside and powder that has not been washed out of the filling tray. Zanussi ZDV91506FA
    by mrPu » » in Other manufacturers
    Last post by mrPu
  • Beko DIN1531 stops after filling with water
    by Sergey.antonyuk » » in Beko
    Last post by Alexey Arkhipov
  • Holes in the inner stainless steel chamber
    by Oleg72 » » in Electrolux
    Last post by Oleg72
  • First start. Doesn't heat the water and turns off after 20 minutes :(
    by Lisa » » in Bosch
    Last post by Chipmunks
  • When connected to the network, the water inlet valve turns on and does not turn off.
    by DenisM » » in Electrolux
    Last post by Vlad766
