Good evening!
I ask for help with repairing the Beko DIN 1531 dishwasher. In any program (including a 15-minute rinse with cold water) it behaves as follows: drains water, pours water, pause for 30 seconds, pours a little more, pause for 30 seconds, pours a little more (already up to the max level, no more), stops. The timer does not decrease, nothing happens (we waited a very long time).
At the point in the program where the pump should turn on, it does not turn on. The pump itself, when connected to 220V directly, works!
Under what conditions does the control unit start the pump? What can you check?
Yes, with error codes, they are sometimes displayed, sometimes not, I managed to catch Er2, but I can’t find a decryption anywhere on the Internet.
Beko DIN1531 stops after filling with water ⇐ Beko
Автор темыSergey.antonyuk
Alexey Arkhipov
Re: Beko DIN1531 stops after filling with water
When you turn on the rinse or any program, it does not go into washing mode after adding water, and this is constantly the cause of the breakdown
- 967 Views
Last post by mrPu
