Holes in the inner stainless steel chamberElectrolux
Oleg72
Post by Oleg72 »
Good evening. There is an Electrolux machine. I worked for a little over a year. There was a leak in the pan. We found the reason.....a hole with a diameter of 1.5-2 mm on the rib where the filter grille was installed. Soldered from the outside. On the outside there were corrosion spots near the hole. No Two weeks later there is a leak again from the side of the door. Upon inspection, we saw many corrosion spots and a hole at the point of contact of the lower door seal with the bottom of the sink. Other points have appeared along the notch for installing the filter mesh. Help with advice for the reasons for the occurrence of holes.
  • Cdcf 6-07 turns off after filling the washing chamber with water
    by Denis3331 » » in Candy
    Last post by Denis3331
  • Holes in whirlpool dwh m00 w
    by lynxmike » » in Whirlpool
    Last post by lynxmike
  • Bosh E-15 (holes in housing)
    by Alexei » » in Bosch
    Last post by Yuri
