Electro lux esf 45010s does not drainElectrolux
USA
Post by USA »
Good afternoon.
Electric luxury esf 45010s does not drain.
If you apply voltage to the motor, then everything works. What could be the problem? Why doesn’t voltage automatically flow to it when needed?
USA
 Re: Electro luxury esf 45010s does not drain
Post by USA »
That is, if you apply voltage directly to the motor.
  • No drain DSIE 2B10, 1 and 2 blinked, after manual drain: 1-5
    by dsie 2b10 » » in Indesit
  • cleaning the drain/drain hose
    by Alexander B » » in General questions about dishwashers
    Last post by Alexander B
  • Doesn't drain
    by Maria » » in Beko
    Last post by Maria
  • Water does not drain
    by TatyanaOren » » in Bosch
    Last post by TatyanaOren
  • The drain pump does not start
    by Stepan » » in Bosch
    Last post by Stepan
