cleaning the drain/drain hoseGeneral questions about dishwashers
Alexander B
Post by Alexander B »
Bosch machine, built-in, wide. It has been in use for quite a long time (eight years, probably already), although, as a rule, not very intensively.
Combi tablets are mainly used. Salt was not used regularly. Water accumulates. It does not turn on.
Before the first attempt to flush the drain, voltage appeared on the housing, and the RCD did not work, although it is quite sensitive and it goes out at once, sometimes for no reason at all.
The drain hose cannot be unscrewed without disassembling the housing. I hit it a little with the pump - it started up a couple of times. Then it doesn’t turn on again and there is water at the bottom.
What is the best way to correct the situation and whether the reason could be something else (other than a clogged drain). Is it possible to use something like "Mole" or can it completely ruin the machine.
Thank you.
  • Where to buy drain hose for Bosch 58M10
    by notencore » » in Bosch
    Last post by notencore
  • Korting 45165 - Drain hose
    by Andrey_IIAA » » in Discount
    Last post by M_V_alexeeva
  • The pump is running, but the clean hose DOES NOT DRAIN!
    by Dmitriy » » in Bosch
    Last post by Dmitriy
  • No drain DSIE 2B10, 1 and 2 blinked, after manual drain: 1-5
    by dsie 2b10 » » in Indesit
  • Doesn't drain
    by Maria » » in Beko
    Last post by Maria
