No drain DSIE 2B10, 1 and 2 blinked, after manual drain: 1-5Indesit
dsie 2b10
Post by dsie 2b10 »
Good afternoon, please tell me. The machine stopped with a flashing error 1+2 (left) without draining the water. Repeated starts were not accompanied by the usual noise in the first seconds, and after 10 minutes there was a single beep and again flashing 1+2. After draining the water manually, everything began to blink almost immediately after start-up, but there was still no usual noise. I disassembled the coarse and fine filters, drained them to the bottom as best I could, the same error.
 Re: No drain DSIE 2B10, 1 and 2 blinked, after manual drain: 1-5
I haven’t resorted to dismantling and tilting yet
  • cleaning the drain/drain hose
    by Alexander B » » in General questions about dishwashers
    Last post by Alexander B
  • Doesn't drain
    by Maria » » in Beko
    Last post by Maria
  • Water does not drain
    by TatyanaOren » » in Bosch
    Last post by TatyanaOren
  • The drain pump does not start
    by Stepan » » in Bosch
    Last post by Stepan
  • Beko does not drain water
    by Lord Curzon » » in Beko
    Last post by Lord Curzon
