Beko DFS05010 washing program does not startBeko
hujiklop
Post by hujiklop »
After a small flood caused by neighbors on the top floor, the machine stopped working. After selecting a program and starting it, as always, the water drains, then it fills up and then nothing happens, in any program, I waited a long time. If you click on cancel the program, the water is drained.
The first time after the flood, the flow sensor worked, but there was not much water in the pan, it was pumped out quickly, and even the dishes were washed once.
I removed the tray, everything looked fine, there were no traces of water, the felt was dry, no water seemed to be pouring onto the door, the inside was also dry.
hujiklop
 Re: Beko DFS05010 washing program does not start
Post by hujiklop »
I disconnected the drain hose and put it in a bucket. After the start of washing, after a while the water is drained and the water is collected again, the water is drained cold.
  • The dishwasher does not start any washing program
    by demon1ck » » in Electrolux
    Last post by Psy40263
  • Whirlpool DWF 405 does not start washing
    by smokxx » » in Whirlpool
    Last post by Val
  • Washing mode does not start
    by Oleg » » in Indesit
    Last post by Oleg
  • Electrolux ESL94201LO - does not start washing
    by Garr1lla » » in Electrolux
    Last post by Psy
  • The water supply does not turn on/washing does not start.
    by ViperRUS » » in Bosch
    Last post by Vrastrub
