Good afternoon.
Electrolux ELS94321LA dishwasher
Please tell me if anyone has encountered this problem.
The essence of it is that the dishwasher does not launch any washing program.
Errors and there are no signals. There is water supply to the hose. Unplugging it for an hour did not help. I did a reset and it doesn’t help either. I cleaned everything of the filter. The buttons all work, the indicators all light up properly.
I turn on the dishwasher as usual, select the desired washing program, close the door, and it just stands there without action, nothing happens, and after a few minutes it just turns off.
The dishwasher does not start any washing program ⇐ Electrolux
Автор темыdemon1ck
- My dishwasher: Electrolux ELS94321LA
Controller
Ksenia
Re: Dishwasher won't start any wash program
You may be turning on the machine incorrectly, you need to read the instructions carefully
Psy40263
Here you need to describe the process in more detail, if the program had not started when the door was closed, then you would not have collected water. Now the following is interesting: when the door is closed, water is pumped out, and then water is collected and then there is silence?
- 2 Replies
- 56264 Views
