Electrolux ESL94201LO - does not start washingElectrolux
Garr1lla
My dishwasher: Electrolux ESL94201LO
Post by Garr1lla »
Hello everyone!
Has anyone encountered this problem:
Yesterday the PMM stopped working, after starting the program (30 minute wash) it started beeping as if the wash had finished.
And the pump is working .
The machine seemed to be turned off, but the nose was pumping.
I pulled the cord out of the socket, then a minute later plugged it in - again only the pump plowed.
Once, using some key combination I managed to reset everything and start the cycle.
But then I decided to see how it was, and the machine started squeaking again and the pump no longer turned off.
Such a problem.
The machine is three years old, I bought it in M ​​Video .
At first glance, the filter cannot be said to be dirty.
 Re: Electrolux ESL94201LO - does not start washing
salt must be added on time!!!!!!
Denoise007
Post by Denoise007 »
Greetings. Same problem! How did you deal with yours?
Pistachio
Post by Pistachio »
There may be a blockage, check the filter, drain hose, siphon under the sink
Psy
Post by Psy »
Water in the sump, aqua-stop has tripped
  • Firmware for PMM Electrolux ESL94201LO
    by IgorF » » in Fagor
    Last post by IgorF
  • Whirlpool DWF 405 does not start washing
    by smokxx » » in Whirlpool
    Last post by Val
  • Washing mode does not start
    by Oleg » » in Indesit
    Last post by Oleg
  • The dishwasher does not start any washing program
    by demon1ck » » in Electrolux
    Last post by Psy40263
  • Beko DFS05010 washing program does not start
    by hujiklop » » in Beko
    Last post by hujiklop
