Error E 1Discount
Kalyan
 Error E 1
Post by Kalyan »
We bought and installed the car and used it correctly for 4 years, everything is Okay! But the day before yesterday the E1 error appeared for the first time and the water is not draining and there is water in the pan, what does this mean? Who had this happen, if so, how did you overcome this error? Thanks in advance to everyone!
Haildmitry
 Re: Error E 1
Post by Haildmitry »
I also had an E1 error, I decided to replace the reed switch with a working one in the water flow sensor.
In case anyone needs it, the Korting KS 53211BW dishwasher measures the volume of water being filled only using this flow sensor (the reed switch is on a small scarf above the impeller, the impeller behind the left housing cover at the top-back), the pressure switch which is at the bottom right is there only in case of overflow and simply turns on the draining process when the water overflows. The symptoms were as follows: the machine took in water, then immediately drained it, then took it in again and drained it, after which it went into error E1.
torgul
 Re: Error E 1
Post by torgul »
I have the same problem. It starts to take in water and then immediately drains. I noticed that the board where the wheel at the water inlet into the snail is all wet, most likely I filled it with water when I tilted the machine for disassembly. Unfortunately, when it stopped working for the first time, I didn’t I immediately figured out the errors and stupidly went to take it apart. It seemed that there was a leak and the sensor in the pan was triggered, I fixed the leak and now E1 pops up. I have a Samsung DM-M39AHC. Tell me how to check the reed switch?
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
