The dishwasher is not working properlyOther manufacturers
Viktor
Post by Viktor »
The dishwasher is filled with water, then it should spray. But this doesn’t happen. After turning off the device and repeating the operation, the water is pumped out. Then the water comes in and again nothing.
When you open the lid after taking in the water, the water stands at the bottom. Water flows without problems. Also, after draining, the machine is dry.
What could be broken or clogged? Inside, all the holes from the sprayers are clean.
Please help. Maybe someone is familiar with this problem.
LarSon68
 Re: Dishwasher not working properly
Post by LarSon68 »
Check to see if your sprinkler is blocked.
  • Dishwasher beeps when working
    by Miha07 » » in Bosch
    Last post by Miha07
  • Neff dishwasher not working
    by Kotjenochek » » in Other manufacturers
    Last post by Kotjenochek
  • Used spare parts, all working, for Bosch SVR55T13EU dishwasher
    by Serge18 » » in Shopping Row
    Last post by Serge18
  • How to tell if the top imploer is working
    by Quartz Grill » » in General questions about dishwashers
    Last post by Sector
  • Bosch machine not working
    by varna » » in Bosch
    Last post by igor
