Spare parts used, all working, for a Bosch dishwasher
(installed on the SVR55T13EU model), the control board burned out.
1. Circulation pump (seal is leaking, needs replacement) - 2000
2. Heating element assembly – 2000
3. Drain pump - 900
4. Lower sprinkler - 400
5. Upper sprinkler - 400
6. Filter assembly - 800
7. Microfilter - 500
8. Dispenser (detergent dispenser) – 900
9. Upper basket with rollers - 900
10. Lower basket with rollers - 900
11. Guides for the upper basket (pair) – 500
12. Power cord - 500
12. Door springs (pair) - 500
13. Door tension cable (pair) - 400
14. Salt container lid – 200
15. Level sensor assembly – 1000
16. Filler hose with aquastop - 1300
17. Drain hose - 700
18. Heat exchanger - 1500
19. Power button 500
20. Door lock with lock - 1000
21. Salt container valve – 800
22. Water drain valve -1500
23. The set of module buttons is 200
24. Microswitch D42F - 400
25. Sensors – 300
26. Compactor doors – 500
27. Connecting hoses (set) – 500
Used spare parts, all working, for Bosch SVR55T13EU dishwasher ⇐ Shopping Row
Автор темыSerge18
- 29864 Views
Last post by Fedorov.vadim
- 40285 Views
Last post by Mitriy
- 13041 Views
- 12676 Views
Last post by igor
- 29597 Views
Last post by LarSon68
