The Bosch SPV43M00RU machine, which was turned off, began to make noise for no apparent reason. When I opened it, the display did not work, and it felt as if the drain was working. Doesn’t respond to button presses.
The drain does not work all the time, but it makes noise for a minute and stops. then it starts again..
What could be the problem, please tell me?
Thank you.
Bosch machine not working ⇐ Bosch
igor
Re: Bosch machine not working
Aquastop worked. Emergency water pumping works (even when switched off). Look for a leak. You probably have water in the pan.
- 4902 Views
Last post by Serge18
- 6627 Views
How to tell if the top imploer is working
by Quartz Grill » » in General questions about dishwashers - 1 Replies
- 1956 Views
Last post by Sector
