The machine starts onceIndesit
the old man
Post by the old man »
Good day! Indesit dishwasher, service life 1.5 years. After I washed the dishes with the filter not tightly screwed on (I accidentally forgot to screw it in after rinsing), the dishwasher stopped starting. I called the technician, he did it, washed the dishes 2 times, again the same problem. He recommended cleaning it with citric acid, and it worked again. It only starts every other time. When you turn on the pump, it draws water, but does not circulate. When you reset the program, it drains the water and can start working again in the next mode. What could it be?
 Re: Machine starts every once in a while
Apparently the garbage ended up somewhere in the wrong place. Try to dissolve it with vinegar essence.
the old man
Thanks, I’ll try it, but can you tell me the proportions?
I once directly poured 70% into the entire bottle where the filter was. Nothing was damaged, although it hissed terribly. I waited for about 30 minutes, then started the washing program.
the old man
Thanks for the advice, I’ll try and write back :)
  • The machine starts only after adding water manually
    by Mikhryai » » in Bosch
  • Curting machine
    by Guest » » in Other manufacturers
  • what kind of machine should I buy?
    by Elena Bill » » in General questions about dishwashers
    Last post by Kirlaa
  • The new machine does not wash
    by Elenaled » » in Hotpoint-Ariston
    Last post by Elenaled
  • The machine does not turn on
    by ssob_i@bk.ru » » in Bosch
    Last post by Vlad
