The machine does not turn on ⇐ Bosch
ssob_i@bk.ru
When you turn on the dishwasher, the display does not light up, but the floor indicator light comes on. Car is not working. When turned off, the display lights up and goes out for two seconds, and the floor lamp also goes out. What could it be? Please help. advice!
Oleg
when
- Новичок
- My dishwasher: SGV57T23EU
Re: Machine won't turn on
The same problem with the Bosch SGV57T23EU (when turned on, the LED lights up, but there is nothing on the indicator and programs are not selected either).
I started pressing all the buttons in a row, eventually I noticed that when I hold down 2 RESET buttons and turn on (Power), the dishwasher turns on with an indicator with code C6, when I release RESET on the P0 indicator, The wash button 50 is lit and the quick wash button 45 is blinking. Then I press the button. wash 50 (P1 lights up on the indicator), then on the button. wash 45 and water starts to fill (indicator 00); when the water is filled, the dishwasher beeps, the indicator shows 01, and then the usual washing program goes through, where each stage is accompanied by a squeak and a step display (02, 03, 04... up to 22 in my opinion). As a result, at the end she stops, I turn off her book. Power, turn it on again and now the dishwasher normally shows the program time and generally works in normal mode.
It seems to me that I run the dishwasher in some kind of test mode, after which it thinks that it can work normally, but this is still not a solution to the problem, since a few days after , like the dishwasher is disconnected from the power supply and not used, the problem with turning it on arises again, and explaining to the family what to do is problematic:(.
Maybe someone knows how, in principle, to solve this problem with does the dishwasher turn on normally?
Thanks in advance to everyone who responded.
Yuri
- Интересующийся
The dishwasher is built into furniture and will not show the display when the door is closed. Regarding:
"I started pressing all the buttons in a row, eventually I noticed that when I hold down 2 RESET buttons and turn on (Power), the dishwasher turns on with an indicator with code C6, when I release RESET on the P0 indicator, The wash button 50 is lit and the quick wash button 45 is flashing. Next, I press the wash button 50 (P1 lights up on the indicator), then the wash button 45 and the water starts drawing (00 on the indicator); when the water is drawn, the dishwasher beeps on the indicator 01, and then the usual washing program goes through, where each stage is accompanied by a squeak and a step display (02, 03, 04... to 22 in my opinion). As a result, at the end it stops, I turn off its Power button, turn it on again and here the dishwasher normally displays the program time and generally works in normal mode. "
that’s right, this is test mode S:00
Yuri
- Интересующийся
You need to press the Start button and hold it for 3 seconds. Close the door, wait about a minute for the program to be recalled. Turn off and on.
Will this be an error reset? As far as I have found information, after the test mode all previous errors are already reset, but my question is that after a long period of inactivity without power (mains), the PMM turns on only in test mode, after which it works normally again until idle time without power, and how , in fact, this is to treat.
For information sake, I am attaching a file about the service mode.
- Bosch ПММ программа тестирования.pdf
- (188.54 KiB) Downloaded 944 times
when
- Новичок
when
- Новичок
Okay, but the question is how to get the dishwasher to work after being idle without running it in service mode:\
- 23865 Views
Last post by Ola from Nekrasovka
- 30923 Views
Last post by s.a.sha
- 2 Replies
- 9048 Views
Last post by Mikhail Lermontov
