Curting machineOther manufacturers
 Curting machine
Hello! My Curting dishwasher is almost new. At first everything was fine, but a couple of days ago problems started. After turning it on (after about 5 minutes), it starts beeping and the RAPID button flashes, SOMETIMES the rinse aid button also lights up, although the rinse aid is full. After about 10 minutes, the machine simply turns off, or it washes, but does not dry (of course it does not wash well) What is this? All filters are clean. Thank you
Harry
 Re: Curting machine
Post by Harry »
Looks like an electronics failure. Is the wiring separate? Is there grounding?
If the machine is under warranty, then you need to call the warranty technicians. If they can’t fix it on site, then they must provide a similar one for the duration of the repair.
 Re: Curting machine
Same problem. The wiring is not separate, there is no grounding.
Dmitriy
 Re: Curting machine
Post by Dmitriy »
Hello! I bought curling. Connected. I ran it through the water for 40 minutes. I turned it on again - it gives error E4. What to do?
 Re: Curting machine
Good afternoon ! I have had a kart dishwasher for 5 years now. Recently a problem started: after washing, all the dishes became white with a coating. I changed the powder, cleaned the dishwasher (everything is there, including conditioner and salt in the machine), but the problem remained - all the dishes were in white ballet. Tell me, what could it be ???
 Re: Curting machine
  • The new machine does not wash
    by Elenaled » » in Hotpoint-Ariston
    Last post by Elenaled
  • what kind of machine should I buy?
    by Elena Bill » » in General questions about dishwashers
    Last post by Kirlaa
  • The machine does not turn on
    by ssob_i@bk.ru » » in Bosch
    Last post by Vlad
  • How to reset a machine
    by to max_k » » in Flavia
    Last post by burn
  • The machine starts once
    by the old man » » in Indesit
    Last post by the old man
